Originally Posted by eyekandi
i've been looking for an angle grinder what speed should i get closet i've found is a 3000rpm or 6000rpm which one is the better of the larger parts.
I just bought a sander/polisher 7-in. variable.
It's kind of diffenent to use. The variable speed control is interesting to get use too. You need to get your speed set then in-gage the trigger lock to hold the speed. It has a 5/8 spindle. I went to ace hardware and got 2 washer and a flat 5/8 nut to mount wheels on with. It seems to work for what i need. I drive a semi and have been doing my polishing with a drill. Needed to step up for a little better job. This machine is noise. i can wear ear plugs.
