frame frustrations
well, the polishing is going allright but still not up to my expectations, and i need to get it done before bikeweek. I have acheived a mirror finish but you can still see some scratches at different angles. I was wondering if anyone else has experienced this. The frame looks perfect when looking down on it but if you get at eye level with a light behind you, you can see the many fine scratches. I recently just finished my heel gaurds and have notice that preperation is everything. You must take your time sanding especialy with your first grit of sandpaper. My heelgaurds are perfect so now I know that i can make my frame perfect I just need to be patcient. Once i am finished I will post some pictures. JOSH
