Done it. Works good.I used a power supply from an electrostatic wet paint system I purchased on ebay for $63.00..I can crank up to 150 KV.................Now if I could just get some various nozzles adapted to this gun...........
Make sure you get the high voltage cable that is made for the power supply,because the cable that comes with the cheap gun will bite you with the higher voltages...............Ask me how I know.
