YOu definetely must sand!...Depending on how rough the casting is, you might get away with starting at 220 wet...to get those pits out though you might need something as low as 80 grit!.Start out high and work lower if need be...don't make any MORE work for yourself!..Good luck with it, and post some photos of the finished product!!! Dave S.
