Originally Posted by pickleboy
i know if galv gets to hot it releases zinc gas, but that is around melting point. it gives me a good start point though so thanks again. i will definietly credit you with the design.
I haven't had any problems with the galvanized coating. The max temperature that I've used is 450deg, not enough to affect the galvanzing.
Gary
