sometimes on steel you may need to sand to 1000 to get scratches out. i dont use sisal or brown for the most part. i recommend that you start again with the spiral and emory keep working this till you are happy with the shine then move to loose white the blue is practically abrasive free and does nothing but add lustre to a shiny part so you have to get the shine you want with the white before using the blue. as for the pits i suggest the cartridge wheels and a dremel or die grinder or drill. they should cut through the steel pretty quick and give you the finish you are looking for then wheel the heck out of it. hope this helps bro and best of luck.
