Old 06-23-2005, 08:41 PM
pickleboy's Avatar
the greaseless is great if you can find wheels thin enough to fit between the fins(i haven't) i settled for polished fin edges on my harley. as for the use there is lots of threads here on application of the greaseless to the wheel, but it basically says to turn the wheel slowley and charge with the stick. if the wheel is on your buffing machine try using a electric or air drill to spin the shaft or try to turn the machine on and back off right away then load the wheel during spindown. my biggest success has been greaseless on felt bobs in a die grinder and dremel. best of luck bro.
