poor adhesion can be caused my many things,bad ground, improper prep work, go with the hobby gun first, that way if you decide not to pursue pc'ing your not out those big $$, the so called hobby gun is the one I use and I have put the sucker thru hell for over 2 years and its still works great. About the only real advantage I can see with a pro gun is being able to adjust the voltage for those tight recess's on parts, but using a few tricks the hobby gun will do it just fine..
Pro-Tech Powder Coating
93976 Ocean Way
541-247-8168
protech@harborside.com
Gold Beach,Oregon
