i tried the aircraft stripper and it pulled off all the paint but the paint on the 3 spokes and the center hub. what can i do? media blast?
Paint stripper should remove all paint. Try it again. Media blasting will work also. Since you're polishing anyway, don't be too concerned about blasting leaving marks.
also there is some slight writting on the wheel, like a raised suzuki and so on...do those need to be grinded off?
That's up to you. If you don't want it there, then you'll have to remove it. You can sand it off.
