  #8 (permalink)
Old 06-30-2005, 10:01 AM
luminous's Avatar
luminous luminous is offline
luminous will become famous soon enough
scocklin,
Thanks for the tips on adjusting dye pH! But isn't it backwards? Wouldn't you use the ammonia to RAISE the pH and acid to lower it?
Sid03,
Where do you buy the lab grade acetic?
I wonder if food grade acetic acid would work as well. I can probably get that locally...
Thanks guys!
