Old 07-14-2005, 10:46 AM
customandsound
Guest
Posts: n/a
Originally Posted by mpierich
Originally Posted by customandsound
I use both the air and the electric.. at the shop i am all air power at home i got both..
Good luck
In that case maybe you can answer my question about what compressor is minimum for keeping up with a die grinder...?
I got rotary it pumps 125psi right at the pump..
But you would need to get a compressor that will hold a good bit of air and run it around 75-90 psi ..
