Old 07-17-2005, 04:41 AM
Paintbalaguy Paintbalaguy is offline
Paintbalaguy
Default Questions about masking and plugging and rectifiers, noob
How do I plug and mask a a internal area on my paintball marker that I want left alone if the body is already anodized and stripping the ano there may affect the tolerances to enough that it will break important air seals and if I only plug it for the ano stripping solution and leave no plugs in the anodizing solution will the internal insulateing ano keep the solution from affecting tolerances, same for the sealing solution?
If I put in a paintball marker that is screwed together with aluminum screws in a electrolyte bath, will the screw get stuck and bond with the marker? If this is not okay to do, is it okay to connect the aluminum wire to all the parts in the bath and hang them in seperate places in the bath and adjust the amps according to the some of the area of the parts?
Also do rectifiers plug into an outlet or just regulate the power from batteries with exact incraments?
I am thinking of buying the small 3 amp one because the biggest parts I need anoed are a a little more than half a square foot if the answer to the second paragraph is no that cant be done but if the answer is yes I will need a slightly larger rectifier but caswell does not seem to have one that will work well enough for anodizing say a trigger which is extremely small and one that will work well enough anodize a 1 or 2 square feet with a good 5-6 amps. This is a real problem for me beacuase I dont want to have to spend the money on 2 seperate power sources for a total of $400. Does anyone no of a rectifier that will do .1 amp to 6-10 amps?
I no alot of these question are noob questions but I just need to get started and get everything I need for this and I dont want get caught with a expensive rectifier that cant handle little parts or one that cant supply enough power for bigger parts.
Thanks for the help, Eric Laakmann
