I did clean the plunger thing and your right it was pretty dirty. But after I put it all back togather it stille would leak by- I'll try the grease idea, hopefully that works. As for air pressure I normally set my line pressure around 40psi and regulate it on the gun but to get it to stop I had to cut it down to like 20- and the gun didn't work that well like that!
Save the trees- burn Rubber!
