Triple chroming question?
Still learning all this chroming process and going to be purchasing a the 4.5 gal triple chrome kit with probably the 60amp rectifier. Ive just beeing polishing everything for the past 5-6 years...and want to move to chroming. Here is my question...i'll try to make it short and sweet.
Ok...it pertains to slightly larger motorcylce items...lets say a SWINGARM
1. Flashing - req's 1 amp or 15 sq in from what i understand. This means flashing it shouldnt be a problem. (Can basically flash things up to about 800 sq in withouth running wide open on the rec.) If so i can flash one half and do the other and then buff out.
2. Nickle bath - basically same as procedure as above.
3. Chrome - 1 amp per 1 sq in. - Maybe have to do it in three sections or so. This is where my concern is. Will most the lines from each dip buff out and show quality (no raised line..ripples, etc. if buffed properly)
IF N E ONE HAS OTHER METHODS TO DO THIS TYPE OF JOB PLEASE POST OR SEND A P.M. I dont plan on doing n e thing larger than swing arms.
