Originally Posted by mpierich
BUT, as I finished up with my 320-grit, it became apparent that the surface I had been working on has an orangpeeled-lookng surface.
But, my question is, how could the orangepeel appear after I did all that with the greaseless to remove the heavy scratches?
I'm no metallugist but it almost seems as though the aluminum had areas of lesser and greater density; the greaseless took more out of the softer areas, hence leaving the orangepeel effect. Anybody else ever see this? If my theory is true, then if I had started with a flat sanding (belt or whatever) it probably would not have happened.
Any thoughts?
hey mike do you know what the alloy was? if it was 2000 series aluminum bar it is real soft. i would guess that the greaseless got the surface hot and started to "smudge" or "smear" the surface . it probable was not visible due to the fact that the greaseless is not meant to shine but to cut. i would agree on the last point about flat sanding most likely would not have done that. but since i use a different kind of greaseless i cant say for sure.
