Old 02-03-2003, 10:20 PM
CamaroMike's Avatar
CamaroMike CamaroMike is offline
CamaroMike
Polishing any kind of steel is fun. I've polished 18 oil pans during my professional polishing career. The best way I found to polish it was to use a grinding wheel, then a sisal wheel with black grease, and spending a long time at the cloth wheels with tripoli. As for pressure goes I really cant explain how much I used, try to go over each part equaly with the same pressure on the work piece. I would get everything smooth with the sisal wheel and then polish the heck out of the trim with the sewn cloth wheels. At first it will seem like nothings happening but after a while you'll see the results. You can make them look like they are chromed if you work at it long enough.
This is my 85 Sport Coupe that I have nearly fixed up completly.
http://www.thirdgen.org/rides/rideimages/ACFmIX2CQ.JPG
