Old 08-29-2005, 04:27 PM
jimcarry's Avatar
jimcarry jimcarry is offline
jimcarry is on a distinguished road
Send a message via Yahoo to jimcarry
Default Re: Electro polishing stainless steel?
Electropolishing Basics
DO NOT TRY THIS AT HOME !!!!!
Commercial applications for electropolishing have been in use since the early 1950's. Most formal research on the process occurred at that time, motivated by the growth and sophistication in electroplating technology. Today there are about 500 industrial installations nationwide, and perhaps several dozen electropolishing job shops.
Electropolishing is often referred to as a "reverse plating" process. Electrochemical in nature, electropolishing uses a combination of rectified current and a blended chemical electrolyte bath to remove flaws from the surface of a metal part.
The typical electropolishing installation is deceptively similar to a plating line. A power source converts AC current to DC at low voltages. A tank typically fabricated from steel and rubber-lined is used to hold the chemical bath. A series of lead, copper or stainless steel cathode plates are lowered into the bath and installed to the negative (-) side of the power source. A part or group of parts are fixtured to a rack made of titanium, copper or bronze. That rack in turn is fixtured to the positive (+) side of the power source.
the metal part is charged positive (anodic) and immersed into the chemical bath. When current is applied, the electrolyte acts as a conductor to allow metal ions to be removed from the part. While the ions are drawn towards the cathode, the electrolyte maintains the dissolved metals in solution. Gassing in the form of oxygen occurs at the metal surface, furthering the cleaning process.
Once the process is completed, the part is run through a series of cleaning and drying steps to remove clinging electrolyte. The resultant surface is clean and bright. In fact, the bright surface is the most identifiable trait...the one that helped coin the name: Electropolishing.
While the process is best known for the bright polish left on a surface, there are some important, often overlooked benefits of this metal removal method. These benefits include deburring, size control, microfinish improvement and others. These metal improvement benefits offer great promise to design and production engineers for cost savings and product improvement.
Although the process is roughly 45 years old, substantial refinements have taken place. Many electrolytes have been developed to allow for electropolishing of a broad range of metals. These newer electrolytes, together with advanced parts handling techniques have combined to improve production yields on a wide range of metal products.
Jim Eaton
