Old 08-30-2005, 02:06 AM
customandsound
Guest
Posts: n/a
Default Re: Hey another question! Powder Gun acting weird
10 psi should work fine. Do you have the caswell gun? if so adjust the screw at the bottom of the handle it also controls the air flow and the moisture filter on the gun is it new? They should be replaced atleast 1 time a month. You may also got some muck building up in the chamber.
