What to replace sand with (blasting) ?
I'm removing a thermal sprayed ceramic coating from aluminum, I had a cheap blaster so I got a bag of blasting sand just to see if it would work, it did, and was fast as well, left a rough surface, which I need a smooth surface. I done a few parts like this, but I don't want to mess up my lungs, so I bought a blast cabinet (no instructions, if anyone knows where I can get one for a ALC sandy blast cabinet) and have tried glass beads, and stainless cast shot, nothing will compare to the sand. The glass beads failed, the cast stainless shot is pretty slow, I mean real slow, what would be a perfect substitute for sand ? This sand that did work is also course, size of coffee grains or close, would the size of the media also have an effect ?
Thanks, Clint
