Re: What to replace sand with (blasting) ?
Hey
how’s it going sand and bead blasting usually leaves a gray dull finish if you are looking for a bright finish after blasting try soda blasting Soda blasting is a process where a surface is cleaned, rust is removed, or coatings (of any kind) are stripped from the substrate (the surface beneath the material you are trying to remove). The soda blasting machine propels a bicarbonate-of-soda-based media via water or compressed air onto the surface to be cleaned. This process gently removes the material without harming the substrate and can be done wet or dry. There are lots of sites on line to show you how to do this
but if you can sand blast this is the same thing
Jim Eaton
