Old 09-06-2005, 01:48 PM
pickleboy's Avatar
Default Re: What to replace sand with (blasting) ?
Originally Posted by rclint
This coating is some more bad stuff, yes I want a perfectly smooth polished surface, I can deal with some amount of hand buffing, but from sand, to bead, to buffer is still a lot of work. This coating you can hold it on a buffer with a coarse wire brush, all you will see is sparks, will not touch the coating, Thanks, Clint
if its a ceramic coating of some sort, then the only way to get it off is blasting with alum. oxide, silicone carbide or other very aggressive media to remove it. there is not much you can do about the extra steps to get the polished finish you want
