Old 09-08-2005, 05:28 PM
jimcarry's Avatar
jimcarry jimcarry is offline
jimcarry is on a distinguished road
Send a message via Yahoo to jimcarry
Default Re: Anode size for 20" wheel? / cleaning anode
A 4"x8" anode will plate approx 32sq feet so I would have to say that yes you should have no problem with the 18x18 anodes remember that with the copy Chrome agitation is every thing get plenty of it the tank should look like it is boiling also I have found that if I use this formula works much better instead of 1 amp per 16sq inches try 1 amp per 32 sq inches and run the solution at about 95 to 110 degrees . For cleaning I simply rinse and soak in sp degreeser then rinse and dry
Good Luck
Jim Eaton
