Old 09-25-2005, 03:28 PM
GramSlam GramSlam is offline
GramSlam is on a distinguished road
Default Re: Anodizing calculations (720 Rule)
-------------------------BETA TESTERS NEEDED-------------------------
Over the past eight months I have been developing software based on the “720 Rule calculations” that I learned from M_D and our unforgettable friend Fibergeek.
The purpose of this software is to make any anodizing run highly accurate and precise, without compromising simplicity. The first version of this software will require the operator to populate three data fields (Estimated surface area, Current density, and desired thickness) at the beginning of the run, and update two data fields (Voltage, and Temperature) during the run.
I require three very active anodizers with a very good understanding of anodizing theory, and high quality equipment to allow for accurate measurements.
I will also require two people who are relatively new to anodizing, but are dedicated to following procedures, and learning more about anodizing theory.
To apply for Beta Testing, please send me a PM with:
-Description of your anodizing experience
-Full description of your lab setup
Candidates chosen for the Beta test will be asked to sign a NDA. (Nothing personal)
I would also like to extend an invitation to Caswell and to M_D to join the beta testing.
There will be two versions of the finished product. One will be strictly an application; the other will have full automation capabilities when used with GPIB and/or DAQ. Both will be dedicated to the memory of our friend and mentor, Fibergeek.
Thank you,
Graham
