first timer needs advice
Hey I just ran my first anno batch today and had some questions about my results. I am running 4 scrap pieces of metal with a combined surface area of 45 sq inches. I put this into the 720 calculator and it told me to set the amps at 1.38 and run it for 20 minutes with its peak voltage being 11.25. Now my first question is because of my PS, I can set the voltage on it but not the amps, there is just a analog readout of them. So how should I approach powering the parts up? What I did was set the amps to about 1.5 with the voltage dial and let it go. The first thing i noticed was that there were almost no hydrogen bubbles forming, except for from a hole that I drilled in the part a few weeks ago. After about 25 minutes I pulled the parts out and measured their resistance with an ohmeter. They all were in the 30-40 ohm range which I thought ment that they had a good layer on them but i guess not. I took one of the parts out and put it in the dye tank and left the other in for another 25 minutes. The one in the dye didn't take any dye and when I took the 3 out of the acid tank that they had been in for 50 minutes now they still ahd the same 30-40 ohm resistance. I used a voltmeter to measure the voltages on all of the wires while it was going and they all had the same so they are getting power. Voltage was around 11 after i had turned it up to 3 amps. Prior to putting them in the tank I put them in the degreaser for 5 minutes after which they passed the water test and then in the deoxidizer for 3 minutes. To attach the parts I threaded the radio shack wire into them and also into the hanging rack.
Thats all the info i can think of now, ask if there is anything missing. Where am I going wrong?
Also can you leave dyed parts out without sealing them and still be able to seal them later? If yes then how long?
Thanks a lot for the help
