Re: anyone ever mix two powders together???
I have tried mixing powders together without much luck. First, the two must be of the same formulation for it to work IE., epoxie & epoxie or TGIC & TGIC etc. Usually when you mix powder, each separate color powder will show up. This is why it is vital to clean your hose and equipment very well when applying black or white colors. Any remaining powder WILL show up as dirt specs in your finish. Remember that powder veins are two different types of powder that are mixed together and have a reaction once they see heat.
