Old 10-07-2005, 10:59 AM
rclint rclint is offline
rclint is an unknown quantity at this point
Default Upgrading some things
Not sure what happened to the last thread ? Was something posted that should not have been ? If I'm breaking any kind of rules please let me know.
Anyways on to the upgrading.. Tank, Thermometer etc
I was at local walmart and spotted a 30 gallon Igloo Polar cooler $40, I checked it over, after I compared to the sinks posted in other threads I thought the cooler was much better built, and a nice built in lid as well. Now I need to fix me one more drain connection, I will then have a pipe connection to feed the pump, and also for the agitation. At 20 gallons per min on my Little Giant Model# TE-5-MD-HC I should have no problem on that. I plan on adding a chiller as well, the one that goes to 0* C, so I will need to fix yet another pipe for this so I can tune down the flow to 7.5 gallons per min (450 per hour).
Thermometer... Same wallyworld, $8 it's digital has a plastic probe on a wire. I may seal this in some type of plastic sleeve like they use on people when the take your temp, because it has one side open with a stick foam piece on it peel that off and the wires are exposed.
Now I just need to find a good way to fasten my lead cathodes to the side, with all the agitation they may go air born
Clint
