frame frustrations.
Finally finished both sides of the frame of my bike and have learned alot from this forum. A couple of tips for begginers: USE ANODIZE STRIPPER It will be money well spent also it provides for a much better finish because you dont have those deep scratches from sanding with grits like 180 or coarser. You can also fit two of caswells 4" buffing pads on an 1/2" arbor that caswell sells if you are using a drill. this allows you to cover more space and get more of a uniform finish. Thanks everyone for all the help during my project. Josh
