Re: Plating Diecast
Plating die cast (or Pot Metal) can be tricky, but we've come up with a few products to help you.
All polishing should be done prior to plating. Plate the die cast with our Flash Copper Kit.
After plating with the primer kit, the part will be copper plated. Polish again, then you may plate with brass-gold etc. See our kits page for info on other plating products we supply.
Good luck!
