Old 10-21-2005, 05:43 PM
tavo1765 tavo1765 is offline
tavo1765 is an unknown quantity at this point
Default Re: How do I PC wire wheels that can't be taken apart
if you get the gun to close it will create more of a problem with the powder back ionizing, also quite possibly K.V fry if you already have a coat on there which you will just see the powder fall off and not stick. Allow the part to get to at least 200f and spray a nice even coat, make sure you have a fresh clean ground. You should focus on re-covering the entire wheel with another coat, otherwise you will get what looks like sand in certain areas because there wont be enough powder coverage to flow out smooth.
