Re: How do I wire up a 220 to my box?
you are correct about the breaker it has to be double pole. other than that it is the same as any circuit. if you use 3 wire 2 go to the breaker and white to common bar, if 4 wire then 2 to breaker and white and bare ground to common bar and ground stud.
