Re: Help with High Temp Masking Tape
green tape it's a bit tricky but works great
if the blasting you used is too rough it will not stick to the surface or if the surface it's still dirty .
also it sticks better to warm surfaces (over 100deg).
also IT SHRINKS , between 380-400 it tends to shrink a bit
brown tape or glasscloth handle temps better but they are more expecive.
