Old 11-02-2005, 07:32 AM
Sid03 Sid03 is offline
Sid03
Default Re: White spotty haze after sealing and dry
Originally Posted by sswee
I've seen it caused from dissolution, old sealer, tap water being used in a step, and letting the part dry coming out of sealer before the rinse. Since you said you boil to seal, we can rule out the sealer related causes. Most probable would be dissolution or something in the water. What CD and run time are you using? Are you using RO water to boil?
what he said ^
