Old 11-08-2005, 12:20 PM
sswee's Avatar
sswee sswee is offline
Moderator
Default Re: Titanium wire spring clips
As acidrain said, if you use aluminum racking it must be stripped of anodize after each use. The reason people use Ti (titanium) racking is it does not anodize and can be reused without stripping. The thing about Ti racking is since it does not anodize, there is a extra current draw that must be compensated for. Each Ti rack is different and has a different current draw amount depending on the surface area of the rack that is submerged. The down side to Ti racking is it can cause anodizing problems with 2011 aluminum. SS
