Re: Acid copper not bond on flash copper help
Smokeycity is right what substrate are you working with.
Then in between flash and acid copper steps are you polishing the piece or
just rinsing and moving to the acid copper. What grit paper are you using and
what kind of pressure this is a very light sanding process.
When asking a question or giving an answer we should all try to be as specific as possible
Jim Eaton
