Re: Any one have good way to clean that pesky grease after polishing?
i have tried alot of stuff as you have. the 2 best things i have found are aerosol brake clean and M.E.K. either of these will just melt the compound right off. for the really packed in areas i use an old soft tooth brush and the same cleaners with a light brushing and they are fine. best of luck bro. keep in mind the M.E.K. is pretty nasty stuff so be sure to use all the necessary protective gear when handling it.
