Old 12-17-2005, 05:46 AM
remotestartdepot remotestartdepot is offline
remotestartdepot
Default Where to get insulation?
I know a lot of you are using that foil backed foam board, but the local Home Depot don't seem to carry that stuff. Where is the best place to find that stuff and what should I expect to pay? Also, is there anything else that I can use for insulation? Will good ole Pink Panther fiberglass insulation work, or will it burst into flames.
Thanks for the helo in advance!
Kris
