  #13 (permalink)
Old 12-23-2005, 03:26 PM
cdaeme's Avatar
cdaeme cdaeme is offline
cdaeme is an unknown quantity at this point
Send a message via AIM to cdaeme Send a message via Yahoo to cdaeme
Default Re: Could a home-brew Babington Waste Oil Burner be used to fire a PC Oven?
Here are pics of the booths one will be a pc booth and the other a oven. The bad part about them is I have to shorten thm because of ceiling height in my basement. Still trying to decide which will be thebest suited size for the oven. These are metal booths inside and out with insulated walls. I will remove the windows from the booth I am using for a oven and fill with insulation and sheet metal. This will be the first project for the PA Blaster.
Jason
could-home-brew-babington-waste-oil-burner-used-fire-pc-oven-booth-1.jpg   could-home-brew-babington-waste-oil-burner-used-fire-pc-oven-booth-2.jpg
