Old 12-23-2005, 11:35 PM
sswee's Avatar
sswee sswee is offline
Moderator
Default Re: New to Powder Coating
That's it in general. I would recommend also an IR thermometer. The cure time starts when the part reaches the cure temp. and that can vary in time with material and mass. It's not a bad idea to make some sort of spray booth. I have pics of mine in the album, that has worked good for auto parts. It's based on others seen here. I'd also get 1lb of several colors. Once you get started, you'll want to PC everything. SS
http://www.caswellplating.com/powder/ir_therm.html
