  #19 (permalink)
Old 12-26-2005, 09:43 PM
BerkelUSA's Avatar
BerkelUSA BerkelUSA is offline
BerkelUSA is an unknown quantity at this point
Send a message via AIM to BerkelUSA Send a message via MSN to BerkelUSA Send a message via Yahoo to BerkelUSA
Default Re: Removing rust in a mc gas tank.
Draino with Lye and a gallon of hot water.. Wear gloves and NEVER seal the tank off.. (you will feel it generating heat), If it will take the rust-flakes off the inside of an old radiator it will do the same for a tank..
Then again there is the Molasses way.. (research that one as yes it works)
or reverse electrolysis from the inside?
WARNING: If your petcock on that tank is aluminum and you use muriatic expect it to be destroyed.. and the fumes can kill you..
Ever drop an aluminum carburetor in a coffe can of muriatic acid at the junkyard and leave it inside a car in the sun on a hot day?
When you return an hour later the interior may "look" good, but it crumbles when you touch it..
Rob
My site & DIY Groups:PABLASTER - Rob's Projects - Powder-Coating - Metal-Casting - Lathe Group - 1930's Chevys - Fiberglas' - CNC Tables - GOT LINKS??
