  #9 (permalink)
Old 12-26-2005, 09:43 PM
rclint rclint is offline
rclint is an unknown quantity at this point
Default Re: What to replace sand with (blasting) ?
Just and update, aluminum oxide did remove the coating, left a pretty rough surface that I took down as much as I could with finer grades of media. I would have thought stainless steel shot would work, but it would not remove the coating either, aluminum oxide is the only thing that I tried that had any effect on it.
Hope this helps someone else.
