  #26 (permalink)
Old 12-27-2005, 06:04 PM
Popeye Popeye is offline
Default Re: Oven using metal studs and aluminum
I'd do like a 5" on both, you can add dampers like you said to control the volume. Make sure to run the vent outdoors... if going through a combustible wall make sure to use "B" type vent pipe and maintain 1" clearance.
