Old 12-30-2005, 07:50 PM
engineerscott engineerscott is offline
engineerscott is an unknown quantity at this point
Default Anyone use the Iron Phosphate Primer?
I interested in any experiences anyone has with the Iron Phosphate primer? Specifically, I want to know if this is a conversion coating or if this is a primer that sits on top of the metal. The description on the website doesn't really give me enough information. A MSDS sheet would help. If it is a conversion coating (i.e. something that converts Iron to Iron Phosphate) then I think it will be mostly Phosphoric Acid (with maybe some detergents and surfacants thrown in). It would not have any appreciable thickness and should turn the metal dark gray or blue.
I am about to start restoring an old car. In a modern car they run the body panels through an Iron Phosphate conversion wash before priming and painting. This gives the metal some inherent corrosion protection and gives the primer a better surface to stick to. I'd like to duplicate this process both for painted and powdercoated finishes.
