This is my first polishing project on my 2004 honda sabre im doing my wheels right now but im not quite getting the results i want (chrome like) they look shiny at a distance but if you get real close its hazy looking i wet sanded with 400 then i used a 3m gray rotolock then 600 then used a 4" sisal and black bar on my drill @ 2800 rpm and on to spiral w/black then spiral w/brown then loose w/white my gut feeling is the drill speed but i want to here from the pro's i do have a 3/4hp buffer and 10" wheels but the wheel is heavy and i don't know if it will get in the wheel's tight spaces what would you use?
