Old 01-04-2006, 01:38 AM
hvac60441 hvac60441 is offline
hvac60441 is on a distinguished road
Default Re: Anyone Looking To Build Like This One?
I Used 22 Gauge Metal In The Interior And 24 On Exterior. The Blower Is A Double Shafted Motor With 2 Blowers Which Blow Air In And Down Thru The Duct And Out The Holes In The Wall. The Return Comes From The Bottom Across The Elements. I Have Found Pulling Air From The Bottom Instead Of The Top Works Better To Keep A Even Temp. I Used Unistrut To Build A Rack Inside And You Can Slide The Hanger To Any Height. I Also Used Bolt Hangers For Larger Heavier Items. It Took About 20 Hours To Build This From Scratch, And About 300 Hours Of Research
