Originally Posted by hvac60441
the angle u can buy at a local hvac supply its 2x2x96 inches and the stat is from a standard oven mouted in the middle 1 inch off the wall it is within 25 degrees of being accurate.
Im considering trying to make 1 like the refridge I just read over but cost wise what does your design run on materials?
and as a circulation question will holes along the bottom and top both allow heat to flow as well as gas escape or do you really need a fan to criculate the heat?
