Re: What is the best way to polish steel?
John,
as far as sanding before sisal, would you think sanblast then sisal or greasless followed by sisal and if so what starting grit and ending grit? At what point is the greaseless finer than the sisal/emery combination. I dont mind putting in the work I just dont want to spend weeks of unnecessary work on it.
Thanks
Zonker
