Old 01-24-2006, 12:25 PM
mpierich mpierich is offline
Default Re: What is the best way to polish steel?
Originally Posted by steelvision
John,
as far as sanding before sisal, would you think sanblast then sisal or greasless followed by sisal and if so what starting grit and ending grit? At what point is the greaseless finer than the sisal/emery combination. I dont mind putting in the work I just dont want to spend weeks of unnecessary work on it.
Thanks
Zonker
If you're having someone else plate it, ask them how they want it prepped. (I guess if you were plating it yourself, you would know already!). I'm pretty sure they want some tooth on there but the plating guys will know more. In fact you might want to post over in that forum.
I doubt that blasting would help, unless the frame needs to be cleaned. It won't do anything for the scratches - in fact real aggressive blasting might just make more work for you.
<<At what point is the greaseless finer than the sisal/emery combination.>>
I've only seen greasless up to 320 or so - definitely not finer than a sisal/emery finish.
If there's one thing I've learned over the past few years, it's that words like "fast", "easy", and "shortcut" simply don't apply to polishing (not a comment about your post, just a fact).
