Re: Wiring Oven
Ok, got the contactor and elements today. Gonna go to the shop after class (which im in now). But, can i use the power wire from the back of the oven to hook up to the contactor that way i dont have to wire up a plug? And is 10ga good enough or should i go a step bigger? Also what do i hook the ground up to?
And you said something about mouting the switch inside something?
