Originally Posted by mpierich
I'd wait a month if you can. Keep it in a warm place. Use a lttle detergent. Light pressure. Go in one direction.
if you cant wait that long then you can try to force cure it in the oven on the lowest setting for about an hour. if you use the house oven then you will need to run the self clean cycle after to cook off any residue.
