Re: Wiring Oven
10 ga will be fine for the internal wiring. Make sure the wire does not come in contact with any hot surfaces or exposed to the direct heat. Ground to the metal frame of the oven. The reason I mentioned something to mount the switch in was to reduce the exposure to live wires once the oven is operational.
Jason
